February 26, 200619 yr My Local Yamaha dealer puts Mobil 1 fully sinthetic oil in mine. I've been told you can't interchange between sinthetic and semi sinthetic so you should find out what is in already. Regards Robbie
February 27, 200619 yr i would say what you put in depends entirely on where, and how you ride. i wouldn't worry about synthetic/semi synth stuff... use what is recommended for your conditions... just thoroughly drain your oil, and put a new filter in, and then top off. never heard of synth/semi synth/dino oil problems when you do a full change. those oils aren't compatible with each other (as in don't add a semi synth if you're running a full synthetic, or a dino oil if you're running synth etc.). what is recommended for your bike to start with?
February 27, 200619 yr the manual says to use 10w-40 oil this covers all riding condition apart from racing, the alternative is 15w-40 but only in warner climates (uk summer) i use a semi sythetic all year round and change it every 6 months and my thundercat is purring like a kitten. and that is with covering aprox 10,000miles a year. im not too sure if you can mix full and semi oil but ill look into it.
