This is the first thread that I posted on here, so I'm hoping its in the right area!
I have had my wr125r for around 7 months now and up until a few weeks ago it was working fine on everyday use, now when I turn the key there is no whine from the fuel pump, it will turn over but it won't ignite. I have changed the battery in hope that the battery was the problem as it failed a drop test and I was advised to get a new one. I have put a multimeter on both the battery and the fuel pump, the battery is reading 12.48 volts and the pump power point is reading around 12.33, but when I turn the key there is still no whine. I have opened the fuel cap and turned the key to listen if there is any noise from the pump, but all I can hear when I turn the key is a clunk coming from the bottom of the tank but no whining.. Is my fuel pump knackered?
Sainz
Yes saintz . remove tank,, its an easy fix,,,, now go introduse yourself,,, and not be a one post wonder,,,, :fingerwave:
Yup fuel pump is fucked.
Thanks guys removed the tank and old pump tonight, new one is on order, I'll update the thread when I have fitted the new one.
Thanks again guys!
Time to go introduce myself!
Whey hay " :spin2: , good you got the tools out,,, i "v seen a scouring pad sucked into a fuel pump on R6.. and bubble wrap on YBR125 ... how it got in there :shrug:
Fitted the new pump tonight and the wr125 fired back into life! Couldn't be happier!! Thanks again guys
I might open the old pump up to see what may have caused the failure.. If it's anything as unexpected as scouring pads or bubble wrap i'll let you know haha!
:thumb: Job done.....glad you reported back,,,as 1 hitters just disappear ,,,
