Posted July 5, 201411 yr Got my YB100 sorted now the RXS has decided to play up. The problem I got is the horn - indicators & brake lights aren't working. the headlight - sidelight - rear light works. Tried a new battery but still nothing. Any ideas
July 5, 201411 yr Moderator So everything fed from the battery via the ig switch doesent work. Hmm where to start. Battery Fuse Brown wire with white tracer (i think) to ig sw Ig sw and connectors
July 5, 201411 yr Author Thanks will go and have a look. Give me anything mechanical bike car lorry engines gearboxes etc no problems electrics puzzle me
July 5, 201411 yr check the grounds ( earths) and put a test light to the feed side of the ig sw ,and then see if you have power comming out to the different parts
July 5, 201411 yr Author If I put a live from the battery to the brown wire on the front brake light switch everything works as it should. So there must be a break in this wire somewhere
