Yamaha RXS 100 electrical problems
Got my YB100 sorted now the RXS has decided to play up. The problem I got is the horn - indicators & brake lights aren't working. the headlight - sidelight - rear light works. Tried a new battery but still nothing. Any ideas
So everything fed from the battery via the ig switch doesent work.
Hmm where to start.
Battery
Fuse
Brown wire with white tracer (i think) to ig sw
Ig sw and connectors
Thanks will go and have a look. Give me anything mechanical bike car lorry engines gearboxes etc no problems electrics puzzle me
check the grounds ( earths) and put a test light to the feed side of the ig sw ,and then see if you have power comming out to the different parts
If I put a live from the battery to the brown wire on the front brake light switch everything works as it should. So there must be a break in this wire somewhere
Sorted, broken wire in the loom under the tank
