Yamaha Gladiator SS125 Missing Problem
Hi Everyone I have Yamaha Gladiator SS125 2011 model. First year was smooth but after that some missing problem started which occurs rarely but after that the missing problem started occurring frequently. Even service center people aren't able to rectify the problem.
The problem which I am facing is the bike's engines gets off automatically even riding at low speed. Kick start takes time to start the bike and self start needs 2 - 3 shots to start the bike even the battery is new and fully charged.
Secondly changing the gear makes a lot of noise also, specially dropping the gear and some times gear gets stuck in between second & First.
Please help to resolve this.
:icon_sad::icon_sad::icon_sad::icon_sad::icon_sad:
Right last problem first - stuck between first and second - this might mean you need to adjust the clutch cable, although false neutrals do happen on all bikes, second problem - misfire - try changing the High tension (HT) lead and the spark plug and see if that is the cause of your problem, probably the cheapest first fix, if that don't work come back and try again. The reason it stalls at low speed is because of the misfire so if you fix that then most of the other problems will go away on their own. :jossun:
