Removing graphics DT 125 RE
What's the best way to remove tank graphics off a Yamaha DT 125 RE? I have removed all others with heat but tank graphics are refusing the budge.
Have they been clear coated over? Some do this to keep the fuel from damaging them, try rubbing them down with a bit of wet & dry then try the heat gun again. My best guess anyway. :shrug:
Yer i garrentee that they have been clear coated on. Only way to get them off is to wet and dry them as said above then if you haven't gone too far down the clear coat get some auto glym paint renovator and buff it back up.
If not your going to be spending atleast 2-3 days re-doingall that cclear coat.
