5mm id Nitrile hose
Hi
to find out the best possible material choices for the tubing, do a google search for 'coleparmer chemical compatibility database'
it is a data base that lists amongst other things elastomer materials and their resistance to chemical attack from various chemicals.
Buna Nitrile is a good choice as are
Fluorocarbon elastomer's aka 'Viton'
hopefully this may make it possible to to have a broader choice of tubing suppliers
I just used a load of windscreen washer hosse that i had laying around from my scrapped cars, works pretty good although i havent used the vac gauge for years.
I've just replaced mine with wiper hose too, works well. It only sees a vacuum, so as long as you don't douse it in petrol it'll be fine. All motor factors stock it too.
Incidently the hose they supply in those kit is attacked by air! or so it seems; it is utter junk
Ive always shows like stafford the best places to pick up stuff like this, usually cheap and plenty available. Cant stop buying when i get there cos everything you may ever need is on one site
ive ordered some from here cheapest i could see
