Posted June 16, 201411 yr Hello, I've got a bike that starts, idles fine but 3/4 throttle backfires pretty bad. Messed with the timing no change. Put a timing light on it and seems like the mark on the magneto is about 2" early on the pulsar pick up. So, maybe the cdi? Someone cut out a lot of the wiring to make it more of a dirt bike. Anyone have any ideas? Thanks in advance
June 17, 201411 yr Well you dont have alot of options here,pick up coil and cdi are the only 2 things left.Check all connections to ensure they are not vibrating loose ignition switch and kill switch as well.
June 17, 201411 yr Author Most of wiring is cut out, no key but I tried connecting the red and brown wire out of the terminal, no change. Will check wiring again. And woodruff key is good
June 18, 201411 yr Author Cdi no points, no key and the kill switch is a wire that you touch to the handle bars. No blinkers , no headlight, no voltage regulater, and the only electronics left is the cdi box.
June 18, 201411 yr Moderator mike is there a brown wire on the cdi? if so what have you connected it to?...It should be connected to battery+ and switchable
June 28, 201411 yr Author I'll look, I do know that the key is gone, so I tried connecting the brown and red wire together and no change
