75 dt 400 out of time?
yamahamike
This post is 3790 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hello, I've got a bike that starts, idles fine but 3/4 throttle backfires pretty bad. Messed with the timing no change. Put a timing light on it and seems like the mark on the magneto is about 2" early on the pulsar pick up. So, maybe the cdi? Someone cut out a lot of the wiring to make it more of a dirt bike. Anyone have any ideas? Thanks in advance
Link to comment
Share on other sites
Sounds more like the coil is breaking down,I would swap out the coil first.
Link to comment
Well you dont have alot of options here,pick up coil and cdi are the only 2 things left.Check all connections to ensure they are not vibrating loose ignition switch and kill switch as well.
Link to comment
Most of wiring is cut out, no key but I tried connecting the red and brown wire out of the terminal, no change. Will check wiring again. And woodruff key is good
Link to comment
Cdi no points, no key and the kill switch is a wire that you touch to the handle bars. No blinkers , no headlight, no voltage regulater, and the only electronics left is the cdi box.
Link to comment
  • Recently Browsing
