Dragstar 650 rectifier needing replacement
What colour cables are going into the 6 pin white plug?
No need to get one specially made with long leads
These peolpe can supply you with plug connectors/spades etc to make standard rr fit your existing lead
www.vehicleproducts.co.uk
Its what I did with mine as previous owner had bodged the connections
That is bizzarre as feck...
Looking at the Yammie microfiches, it seems you have the 2002 XVS650p/pc, whereas most models have the same unit as used on the 2002 650ap/apc.
That's a bit of a bugger...
I suggest as NSD does and get an extension cable made up so you can fit a normal unit. It'll be cheaper than a custom reg/rec, for sure!
The nice people at electrex in Oxford have agreed to make me a reg rec with an extra long cable for an extra tenner. One that unplugs both ways, so should not be a problem in future. Thanks again for all the advice peeps, saved me having to return incompatible parts!
Tout, what is the big white 6 pin connector in the 1st pic? was that connected to any thing?
That is the RR connector, hence the cable length issue.
Thanks for that NSD, rang them this morning, they didn't have the plug in question.
And it looks like Electrex haven't delivered on their promises either, a rather bored lady on the phone said there is no lead time for my order (though they said it should be ready end of last week). Couldn't wait to get me off the phone. Told them to stuff it. Looks like I'll have to go OEM in the end...
Whoooaaa..
I got around the plug connectivity problem by carefully cutting away the yam plug from the spades inside of it. The spades then push into the VWP plug and lock in using the tabs
Do the same at the other end
Make up a lead using the other ends of the VWP plugs
Hope that makes sense
That means you can buy a RR from M&P for example, and make up an intermediate lead, VWP sell all the spades/cable/heat shrink etc to do it
