TTR 125 CARB
can anyone advise my daughters TTR 125 has a choke that will not pull out to its full potential, I tried WD40 but no luck, removed the locking nut on the carb cable but this will not pull out does anyone know the exact lay out of the choke into the carb?????
Not sure of the year or particular model of TTR you have.....but does this help? :unsure:
Thank you very much for the diagram it is the exact one on my daughters bike, do you have the page with the listing of parts to go with the diagram.
Once again thank you for your time and information.
No problem GOD9....glad I could help. ;)
This is the site where I found that view......MotoGrid
It's been quite useful to me when I needed Ignition parts for my XT. They're cheaper than a dealer but still are parts directly from Yamaha. After comparing prices to my local dealer, I found that I saved @ least a couple hundred $$ on my Ignition parts alone. I'm now thinking of replacing my fuel petcock through them, which'll only run me $35....compared to an easy $50 from the dealer. The exploded views like you'd find on a microfiche, come in real handy......for reference if anything. ;)
Best of Luck with your Carb issue. :)
