Posted June 7, 201411 yr Hello Folks, I was wondering if someone could help me with an electrical issue on my Yamaha EW50 Slider moped? When the Slider is cold and I turn on the ignition I have a working horn, indicators and brake light. When I start the ped I lose all of those and the headlight is very dim. I've tested the battery with a multi-meter and it's showing 13v with the engine off, but I'm not getting any voltage rise with the engine running. I'm guessing the problem could be one of four things: 1) A dodgy stator. 2) Bad earth (I can only find two - one on the starter and one on the coil and they both look fine). 3) Regulator/rectifier (gets very hot, very quickly) 4) Shagged battery. Has anyone had a problem like this before, or has anyone got any idea what the problem could be? Many thanks, Jason
June 7, 201411 yr Author http://www.electrexworld.co.uk/acatalog/Troubleshooting-3P-PMG-&-RR.pdf Brilliant, just the job! Many thanks.
June 7, 201411 yr Author start with a new battery first as its the cheapest option. Going to try a swap with my RD125LC tomorrow. Duh, didn't think of that. Cheers.
June 8, 201410 yr When I had a Piaggio ped I had a similar issue and turned out to be the rectifier. Cost was such I got rid and bought a 125!
