Rev lights
I have the DATATOOL rev lights off my 1200 Bandit. I know that these are meant to be fitted to electronic tachos but DATATOOL say it might be possible on the thunderace to connect to the crank sensor:-below
I want to fit a Revlight to my machine but it is not equipped with a tacho? »
In certain cases this can still be done but you will need to pick up an engine rev pulse from another source (e.g. crank sensor). Don’t use the coil the signal will be corrupted by the collapsing field within the coil as it fires the spark plug.
You will also have to accurately set 4000rpm. Good quality dwell meters and ignition timing strobes sometimes have a revs indicator. Be aware most of these are set for 4 cylinder car engines and you may have to apply a correction factor depending on the configuration of your machine.
Does anyone know where this is on the tnunderace?
