Posted June 7, 201411 yr I own a Yamaha FZS bike, now four years old. I'm experiencing problems during revving up the bike to high speeds. The engine gives up suddenly, the throttle doesn't respond(like what you face when the fuel tank goes dry), but the fuel tank is full, battery is recently charged. Then I need to keep the bike idle for around 10 - 15 minutes, then the engine check light blinks and then i can start the bike again but not for long when this happens again. I have changed the whole electrical wiring twice now but doesn't seem to solve the problem. It works good till a week after servicing the bike, but then this starts again. Please guys help me out to fix this.
June 7, 201411 yr From your description it sounds like some form of fuel starvation. Simple things first. Check the fuel cap of the tank to ensure the breather is not blocked/partially blocked. or it may have a rubber gasket which has become 'stuck' If its blocked as the fuel is used, a vacuum is created above the fuel which will in turn stop the fuel from leaving the tank. As you throttle up, you use more fuel and the vacuum is created. The throttle doesn't respond (like what you face when the fuel tank goes dry). May be helpful?
June 7, 201411 yr Author Okie, thanks for this info, i will be checking on this now, i would also like to know more about the engine check light, like what all checks does it do.
June 13, 201411 yr Author Mine is a carb type. 5 year old now. I have opened the fuel pipe and checked, the fuel flow is normal. no blockage. now there s one more issue that's come up. I have replaced my old battery because it was almost 4 year old. When i try to start the engine, it just gives cranking noise continuously but doesn't start. Full fuel, full battery but no use. Any clues where to start.?
June 13, 201411 yr First thing to check is spark,pull the spark plugs and lay them on the cylinder start bike as normal and see if you have any spark.
June 14, 201411 yr Author i am not able to see any spark, just wanted to know will the spark be clearly visible in sunlight or is it very minute?
June 14, 201411 yr Author anyway, i have replaced my spark plug with Iridium NGK, no luck couldn't start the engine, also can you tell me if iridium spark plug draws more charge from the battery..?
June 14, 201411 yr Don't think Iridium plugs draw more power than normal plugs they are just more conductive than ordinary metals so giving you a better cleaner spark, as to your original problem sounds like you have a dead coil pack if your getting no spark at all, tho it might be a fuse or earth problem, try taking the coils off and checking the wiring and the earth points.
June 17, 201411 yr Author Thanks guys, this has helped a lot, I'm able to start the bike now ...one more help needed though, when the bike is in neutral, the accelerator response is very good, but when changed to first or second gear the response is quite bad at lower rpm, higher rpm is again good. Any suggestions on this...!!
