Hi Everbody , I am going to replace my leaking oil seals and dust caps on my newly purchased XJ900s 2001 , could anybody tell me what weight of oil to use and how much to put in each leg please ? Cheers Dave
Welcome dave, its down to you , how did you like the handling on stock oil.? if its a firmer -less dive your after , go for heavier oil,
:welcome:
Thanks for that , I've not actually ridden it yet just waiting for two horns then to take it for an MOT. I've been told it has Ohlins internals as the originals dived a bit too much for the previous owners liking. Do you know how much to put it or the air gap by any chance ? Dave
Hi Dave, the usual weight for the fork oil is 10W and if your not sure then buy a standard fork oil from you local dealer or off of the net, as to the amount then you "HAVE" to buy a manual as it will tell you what the precise measurements are for your particular bike, if you have not ridden it yet you should start out with the normal/original settings then work out what's best for you as you go along. :jossun:
My bike's manual says sae 10 30 motor oil. I asked my local bike shop what was the equivalent fork oil, he said 10w.
have a look at your manual for details of whats needed for your bike
