June 2, 201412 yr They are, along with the little fairing inners that line the inside of the screen!!
June 2, 201412 yr Well done Dutch, I have just got a second CDI unit so we must be buying all the old parts up. Tasky I have a spare set of inners for the bike if you want them? There the old ones that it came with mostly ok but a bit worn and the odd plastic lip broken but serviceable.
June 2, 201412 yr Author Guys, It was just in a spare 5 minutes at work that I looked on the bay and searched FJ1200 spares, just for kicks. Bang there it was! My nearside one has been damaged in a former life, front is ok but the rear flare has been smashed and broken and now riveted together but wont last long. Thought it was a steal and just to keep me bike in as good a condition as I can........which it deserves.
June 3, 201412 yr Well done Dutch, I have just got a second CDI unit so we must be buying all the old parts up. Tasky I have a spare set of inners for the bike if you want them? There the old ones that it came with mostly ok but a bit worn and the odd plastic lip broken but serviceable. You're on a 3CV, aren't you?
June 10, 201411 yr Author Here it is. Was looking a bit sorry for itself on receipt but a quick wash & polish sorted that. Its in one piece (just) which can't be said for mine. good buy at 30 squids ? It does look like the previous owner has been rock crawling with it The seller described it as follows : THIS IS A BELLY PAN FROM AN FJ1200. IT IS IN GOOD SOLID CONDITION, WITH JUST A BIT OF SCUFFING UNDERNEATH. ALL MOUNTING POINTS ARE SOLID AND INTACT. And my nearside aft - although the general appearance of mine is better than the spare all round.
June 10, 201411 yr Typical of the BAY really, your definition is always a best guess, at least your new one is in one piece, mine is a bit worse for wear, think I will run without it as it only seems to be cosmetic.
