Hello there,
I currently have issues with the power-valve on my DT, when the ignition is turned on the power-valve moves completely so it is not stuck.
However when started the valve does not move at all, is there a rpm return wire to the power-valve that is faulty?
Any suggestions would be much appreciated, Thanks
2 points.
Do you know what tells you the unit has moved?
We're not Mr Fixit, were a bunch of people into yamaha's and some banter. Please, use the new members area to say hi. General 'Hi I have a problem', first posts get very few replies.
  • 1 month later...
I'm a newbie here too. Forgot to go to members are. Going there straight after this....
Check utube there's a vid showing how the ypvs should work. Easier to show than tell.
