Anyone have any ideas about a wobble...
Hey all you peeps i have a queery and would like some help... i have got a wobble on my xvs650. I've changed all the bearings from the front to the back, I've had my front and rear tyres checked and balanced ive also checked the frame for bad dents and cracks just to make sure but it's still there.. it only seems to occure when im between 60/70mph..
did it just start? or was it after a new tyres or anthing..hows the head bearings? disks? swing arm? could be a few things i can think off
but my friend had the same problem on his bandit an it turned out to be the front tyre
Define wobble.
Are we talking butt clenching terror shakes or a slight shimmy you can sense rather than feel. Can you feel it with your feet, your arse, your hands or all.
i have changed all the bearing from front wheel, swing arm bearings head stock bearings i upgraded to racers. rear wheel bearings are also new and ive had a new front tyre fitted and balanced about two days ago..
@ cynic it's more that i can feel it than see it more in my hands and legs.
I'm wondering if it might need to get the front aligned?
I will add i had this before i changed everything. i was hoping all the work i did would have fixed it..
I forgot to ad I've also changed the fork springs as the originals wer fooked and ive also checked them for correct fluid levels and pumped them to make sure of no air gaps..
Define wobble.
nope my arse hasnt prolapsed yet but in this weather i may be close..
Type of tyre , not suiting the bike,,, is it crossing the white lines when wobble,,? Up the pressure a bit,,
Make sure your tyres are the sizes recommended by Yamaha , and that the pressures are correct . Sometimes mixing tyres from different manufacturers , even if the correct sizes , can have a bad effect .
If your feeling it with your arms and legs then its more front biased.
Are the bars rubber mounted? Steering head bearings a little too tight? and front tyre would be my first inspections.
Ok from the top..... no it's not crossing the white line the wobble isn't severe but noticable, the tyre is a maxxi classic as recomended to me. i have checked the front psi and it's at 32. i have no bitch seat. their is no play in the swing arm i changed the bearings last weekend and have checked them again when i had the bike up in the air doing the headstock bearings. the tyre I bought is the recomended size in the handbook 100/90-19". the bars are rubber mounted. i have done a realignment on the forks which has helped..
I havent had chance to check it in the dry as we seem to be having the uk's annual rainfall down here at the mo so all my riding checks are done on wet roads..
ha ha dumb ass here just noticed that he hasnt torqued the front brake caliper up...
:babyha: lovely up here for a change,,, :jossun: , glad you fixed it..
Oh my, checked everything else too?
yep just done a full "is everything tight check?". and now that its dry down ere ill take it for a run and let you guys know later... cheers to all of you for your helpfull infomation i will keep you informed..
lift the wheels off the ground and (one at a time of course) spin the wheel watching the rim where the Tyre bead sits, it might not be seated evenly, if its not, let the Tyre down, push the bead off the rim (inwards), and pump it up again.
That was one of the first things I did. I took the new tyre right of and had a new innertube and the tyre refitted by a motorcycle workshop and got them to check it was seated properly... the only things i haven't done is replace the fork oil seals and I'm going to put another new set of front wheel bearings in just incase they are faulty as i did buy them from fleabay.. to all the others that posted i took her for a run and she still hasa small wobble.. more like a shake now..
