2001 R1 exup
Hi everyone,ive just brought a 2001 r1 and ive got a poblem.when i let of the throttle i get a terrible rattling noise coming from the exup valve ,.When i pull the wire going into the valve it seems to improve the rattle.Any ideas what could be wrong?
Sounds like the cable needs tightening on the servo under the tank. Take the side cover of the exup valve and check that this isnt coming loose too.
It sounds like the vibration is coming from the underside ,on the exup valve itself.Is there anything to be aware of when i remove the cover.Will anything spring off and be lost forever?
Hmm i dont remember there being a spring on there :unsure: Just pretend that there is and you wont have a problem ;)
ok will do cheers for your help.
No probs let us know how you get on B)
Turns out it ws just the cable that needed tightening under the tank.Its running fine now.Thanks for your help guys :D
hi everyone, just had a crash and i need some cheap parts for my r1. I'm after a headlight and top fairing in blkue if poss. If anyone has these parts please let me know via email on [email protected]
