Dt 125 x electrics died?
Everything happened exactly as you explained, does this mean it a wire at fault?
Would it be ok to connect a wire from the brn out of the keyswitch to the brn on the rear brake switch for a few days until I've got time to resolve the problem properly?
  • Replies 45
  • Views 8.2k
I was thinking of splicers to connect it as to not cause too much damage to the wires
Do you think they would do the job?
as a temporary fix it would work yeah, and your neutral light will be an indication that all is well...maybe even toot the horn now and again to be sure. Get it fixed properly ASAP I dont like the idea of you riding around with this long term, it would be good if you come back soon and report that you have fixed it properly ;)
I'll fix it (assuming I can find the afending wire). don't fancy replacing them all :/
Well I've been thinking for a while about having my frame and swing arm powder coated for ages so while I'm sorting the loom it's the perfect opportunity to get them done ;)
Thanks for your help!!!, I would of still been stood looking at it scratching my head lol
