  • Replies 45
  • Views 7.5k
I didn't try operating the controls while the multimeter was on I'll get a better multimeter tmoro and try it
So, I got a new meter today and did a few more tests,battery voltage is 12.3, charge voltage 14.2 so regulators ok but I can't find any power anywhere else
12.3 same as batt, pressing horn push did nothing too
Me either lol
Was wondering if it could be the condenser after reading yamahamikes thread about his 175 from a couple of weeks ago but his bike wasn't sparking where mine does
Tbh I don't even no if my bike has a condenser :/
Lol didn't even no what it was tbh
Just found out its the capacitor lol
Ok I'll try that now
Nothing at rear brake switch
Here's hoping it's not a break in the wiring
The usual place for a break is where the loom goes around the steerer tube at the front, try turning the bars lock to lock with the key on and the brake pressed...anything?
Nothing
Yes, I've checked every connection I could see lol
the only other thingI can think to try to prove the loom is duff is this, unplug the rear brake switch and secure a piece of wire (jumper) between the brn connector to the loom and the battery +, you should find that lights, horn etc now work...disconnect the keyswitch and using your multimeter check the voltage at the loom brn again, you should find you have nothing at that point if your loom is broken. Take the utmost care with the jumper connected to the battery because if you touch any frame components it will spark, so it needs a lot of care. Only do this if you feel competent not because I told you to I cannot be held responsible for any damage caused by your errors. It would be safer with an inline fuse in the jumper too.
