May 7, 201412 yr Hi. Any of you guys fitted an sc projects exhaust to an xj6? I've bought a second hand one and trying to work out correct fitting. Basically the header pipes are numbered 1/4 and I'm trying to work out if it's left to right as if your looking from the front or rear of the bike towards the exhaust. Guy I purshased it of can't help and I've been in touch with sc projects but the language barrier is tricky to get my question across. I've fitted it left to right as if your looking at header pipes from rear of bike but it's niggling me whether this us right it not?! Any clues guys? )
May 11, 201412 yr Author cheers for the reply... think my post got moved so only just found it yes this is what I assumed, actually I recently spoke to a guy who had the same exhaust/problem and he actually fiited his the opposite way to mine,ive emailed sc projects but they're English isn't the best and they cant give me a definite answer either,they suggested I send pix. strange thing is the pipes are having a tendancy to pull to the left and have touched and melted the belly pan(didn't notice when fitted originally) but weirdly enough the guy who fitted his the opposite way has experienced the pipes pulling in exact same direction!! he ended up cutting small part of the belly pan to accommodate this.. ....nightmare eh lol
