Howdy,
my rear shock has broken off at the bottom bracket and have tried to remove the rustified bolt by soaking in everything and belting the bejasus out of it. NOTHING. Any ideas please. Can any one tell me the cheapest place to buy parts for my bike. At the moment I need the bottom mounting bolt seals etc. Most of the sites on here eg Suttons are waaaaay too expensive. Regards
Eddie
a picture would help eddie. shared the same stuff as the fz I think too.
if you go on cmsnl and get the part codes, you can then google it and you might find they share parts with other bikes.
have you tried heating it? freezing it?
cut it off if you can get in with a grinder?
you can use a stick welder if you want to heat it fast, but be careful
