May 4, 201411 yr The oil warning display keeps flashing on my speedo. The bike has done 1800 miles and had a service 800 miles ago. I topped the oil up yesterday and it keeps coming on. I can't understand why it keeps coming on.
May 4, 201411 yr Moderator don't overfill grouch or you'll blow the case gaskets/seals is it an oil pressure light? engine still quiet? my fz has an oil level light and the xs has an oil pressure light. if its the pressure, take it back to the dealer before its terminal.
May 4, 201411 yr Author It's not a light, it's on them, display it just says oil. The bike, is running and sounds fine.
May 5, 201411 yr Author Yeah, I've reset it now so it should be ok. I just don't know why it was showing.
May 7, 201411 yr This is a new bike so you should have the manual, I would check what it says as it could be a fault that you want to get fixed under warranty.
