changing crank seal (LHS) without slitting the case's
bradlerstzr
This post is 3798 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi lads how's it going new to the forum :hyper: have a tzr 125 4fl, and i did a crank seal today :madflame::madflame: nearly sure its the LHS because when i removed the cover there was a few ml of gearbox oil in there :eusa_think: anyway can i change the seal without spliting and removing the engine? any help would be great thanks
Alan
Well you got the post in the right section ,but a hello in the new membersection would help as I/we have no idea about your mechanical ablities.
Might I ask why you think you did a crank seal? that make no sence to me why you would ask how to do it if you did it.
Pssst, no I moved it. :)
For me if the seal has gone, the other will be on its way, same for the beaarings. Fix it properly ONCE.
