Posted April 30, 201411 yr Hi lads how's it going new to the forum have a tzr 125 4fl, and i did a crank seal today nearly sure its the LHS because when i removed the cover there was a few ml of gearbox oil in there anyway can i change the seal without spliting and removing the engine? any help would be great thanks Alan
April 30, 201411 yr Well you got the post in the right section ,but a hello in the new membersection would help as I/we have no idea about your mechanical ablities. Might I ask why you think you did a crank seal? that make no sence to me why you would ask how to do it if you did it.
April 30, 201411 yr Moderator Pssst, no I moved it. For me if the seal has gone, the other will be on its way, same for the beaarings. Fix it properly ONCE.
