Posted April 27, 201411 yr Hi, first time today, just got myself a 900 Divi and the fuel gauge not working although the red light stays on all the time, any ideas.
April 27, 201411 yr Hi You will be better served if you say hello in the new members section, My old Divi had a fuel gauge problem, it turned out to be the pivot bush on the fuel level float sender unit inside the tank was worn, apparently today's fuel does not have as good lubricating qualities as petrol of old, anyhow I changed the sender unit which is easy to do, looking at the old sender I reckon I could of made a replacement bush, but I had already brought a new sender, you could perhaps look at the wires on the sender unit bridge a contact across them making the fuel gauge show full,
April 28, 201411 yr Author Sorry didn't realise I had to introduce myself first, thanks for the advice.
