Indicator Relays?
Hello all
I am searching online for a new pair of indicator relays for my 06 YBR125, since there is a 1-2 second delay when I press the switch. I know it's the relays because they make a loud squealing noise before they start clicking. You can also feel it if you take them out while you press the switch. Pretty dangerous if I need to indicate quickly.
Only problem I'm having is that they are flippin expensive! This is all I can find online:
http://www.motorcycleproducts.co.uk/indicator-relay-yamaha-ybr125-2005-2006-p-247543.html?gclid=CN2LxcK4770CFdShtAodl2EA3Q
15 quid each with about 5 quid delivery, that's 35 quid for a couple of relays. Bit extortionate for some simple electronic components. If I have to pay it then I will, but does anyone know anywhere that I could get them cheaper, or a compatible alternative? They seem to be different to what I find if I search for general relays.
Have you found the same relay (as your link) on YOUR bike and confirmed its running the indicators?
Ie unplug the relay and see what effect it has on the indicators and that it has 4 pins!
The reason i ask is I've done a search on ebay for ybr125 relay and I found there are white 4 pin ones which look identical to your replacement, but its not for the indicator.........
http://www.ebay.co.uk/itm/YAMAHA-YBR-125-CUSTOM-2010-Multi-Function-Relay-/291078877961?pt=UK_Motorcycle_Parts_13&hash=item43c5a73309#ht_2186wt_966
http://www.ebay.co.uk/itm/YAMAHA-YBR-125-57-STARTER-RELAY-3D9-00-ACA12115-M14-/251435929052?pt=UK_Motorcycle_Parts_13&hash=item3a8abfcddc#ht_2340wt_758
This link shows both the 4 pin white one and a 2 pin indicator relay in the same photo
http://www.ebay.co.uk/itm/YAMAHA-YBR-125-CUSTOM-JOB-LOT-RELAYS-SENSORS-ETC-TILT-FLASHER-YBR125-C-2012-/281057891475?pt=UK_Motorcycle_Parts_13&hash=item41705b1493#ht_1297wt_758
and so does this link
http://www.ebay.co.uk/itm/YAMAHA-YBR-125-2007-ERA-VARIOUS-RELAYS-/230953439326?pt=UK_Motorcycle_Parts_13&hash=item35c5e5d05e#ht_44wt_723
Heres a link for a YBR125 2006 model, and its two pin
http://www.ebay.co.uk/itm/Yamaha-YBR-125-ED-2006-125-CC-Indicator-Relay-/390559761317?pt=UK_Motorcycle_Parts_13&hash=item5aef2d03a5#ht_1396wt_966
You see I was wondering why an indicator relay would be 20watts...........
Can you post a photo of both of them? I'm intrigued why there should be two!.......unless a previous owner has ADDED them! now theres a thought!
Your replacement link has 4 pins so if you have two indentical relays you will have 8 pins.
Can you confirm that if there are two and that ALL 8 pins are in use? or are they just using 2 of the 4 pins of each relay?
Or have you not taken the plug off ?
He logged in yesterday?
Sorry everyone I've been dealing with various other problems.
Yeah, my bad, it is only 1 relay. Is the headlight also controlled by a relay? Because my dipped beam (always on) takes about 20 seconds to come on after starting the engine.
