Please help Yamaha YBR 125 2007
Hello everyone,
I bought used non runner Yamaha, which been standing for two years. So I have cleaned the tank, fuel injector, air filter and changed oil and I cant get it started. When turning ignition i can hear tick in the fuel pump inside the tank, but there is no fuel coming to fuel injector from tank so should i replace fuel pump?
p.s. on fuel injector there is brass screw I cant get it out any tips?
Say hello in the NEW MEMBERS WELCOME AREA.
Then
Post questions like this in the WORKSHOP AREA
That way you might (probably will) get the help you need.
:welcome:
Hi" there is a filtre on the pump . remove and inspect, power on and see if pumping wen out,, :wavey:
Hi put a noid light on the injector and see if it flashes,after you check to see if you have fuel pressure.
