Posted March 29, 201411 yr Hello Everyone! Im New Here So As I joined got a problem! On my 2002 yamaha dt125r i have an oil leak out of the left side crank case. i have replaced both side seals but still loosing gearbox oil and leaking it out the other side. It doesnt burn blue smoke it just leaks it all out the left side! it is very frustrating and expensive. Thanks!
March 29, 201411 yr Moderator Ok, firstly you should post an intro in the new members area to say high. Lot of people wont answer people who don't. We figure its better than lots of rules on when and what new people can do. After you have done that you can elaborate on your problem, as in where the oil is coming from on the LH case. Crank seal, output shaft. Gearbox oil from the crank seal is unlikely as it would smoke like a 70's disco. What have you actually changed etc. If that LH seal goes the generally rev till they pop.
March 29, 201411 yr Author Well What i have done to it is; put new seals all round and a new stator plate and gaskets. the oil 100% comes out the lh case. as if i take it off it drops about 1/2 a pint its not clear oil what i put in its blackish, if i may say so. thats all i really know.another thing is that my lh bearing has gone for the cranks but there is no noise just slight movement. that might be it i dont know! THanks
March 29, 201411 yr Moderator If the lh crank bearing has gone none of the crank seals will work properly. If you can actually feel the movement they are completely shot and im surprised it runs properly. Unless you replace the bearings your wasting you time changing seals....
March 29, 201411 yr Author ok thanks. thats what i though aswell but wanted to make shure. ok to the shed i go!!
