xt125 ticking
Hi ya'll
first off, thankyou for having me on your forum, hopefully find some good tips an tricks here...
ok i've recently bought a bike xt125x that i'm doing up (or trying) but i have a ticking comeing from the engine, i thought it was the top end (unsure now)
so i took the top off ajusted the valves to they max, checked the timing chain and tensioner...the timing chain and tensioner looked ok to me, but i can't be 100% sure on that...an new head gasket, new oil as some one had over filled it!
but i still have this tick, its in rhythm an not a random tick...
i don't want to strip the engine if its something stupid....but i don't want to ride it incase its not
anyone got any ideas plez?
tomy
hi same prob with mine it is the top end as i fixed it but when my engine warms up it returns and is really horrible as the revs get higher the noise gets louder
  • 3 weeks later...
how did you fix it?
if its coming back when the engine warms maybe it is the valves, metal expands as the engine as gets hot
2 words weak valve springs,or you havent adjusted the valves properly
weak valve springs! i never even thought of that
thankyou dt502001, an i'll have another look at the valve clearance too...i did set them to their maximum but i'll double check
