out with the flat slide carb dt125r ??????
hi all im interested in changing my carb from a flat slide to a circle 1. im asking if any 1 has done this also what size will i need etc the main reason for this is i cant find a repair it for but i can find a load for the circle type
thanks in advance
p.s or if any 1 knows what other bikes use the same carbs
What bike is it
dt125r 20
02
Sent from my GT-S5360 using Tapatalk 2
The earlier DTRs had a round slide carb I think, if it were me though I'd stick to the flatslide as was intended, is yours goosed then? cant you get one from ebay? or someone here
yeah mines goosed ive tried ebay but the air screws r seized or some thing else is up with them as for asking on here do i post in the wanted forum
I meant look in the for sale section but I see you already have, I'd also sent AndyDTR08 a PM in case he misses you question but he isnt here that often so you may have to wait, theres also the DTR forum...ask NEV
Whats the size of flatside , 26mm/30mm/32mm ? . look on ebay at other make of bikes , that use same size,,is KX125 , KR1. 250
RGV250 . . as may be plentyfull , = Cheaper,,,,
