Hello Again
Does anyone know what the diagnostic codes are for Yamaha XJ6N, or where I can get them? I've looked through service manual but no joy.
The method to extract the codes is in the service manual:
Turn the ignition to off, but set the kill switch to run.
Lift the fuel tank and disconnect the fuel pump connector [easy on the XJ6]
Press and hold SELECT and RESET on the dash, turn on the main ignition, holding down both buttons for a further 8 seconds ish.
'dl' will display on the dash, if done right and you are now in diagnostic analysis mode.
Once in you should be able to cycle through any logged codes.
Bloody hell that's complicated !! What ever happened to hitting it with a hammer till it worked?
Actually pretty straight forward when you compare it to stripping and cleaning a set of problematic Mikuni BD38ST carbs.
thanks pilningas. I've looked through the service manual but can't find what the codes mean.
