DIAGNOSTIC CODES XJ6N
hippyracer
This post is 3894 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
The method to extract the codes is in the service manual:
Turn the ignition to off, but set the kill switch to run.
Lift the fuel tank and disconnect the fuel pump connector [easy on the XJ6]
Press and hold SELECT and RESET on the dash, turn on the main ignition, holding down both buttons for a further 8 seconds ish.
'dl' will display on the dash, if done right and you are now in diagnostic analysis mode.
Once in you should be able to cycle through any logged codes.
Link to comment
Share on other sites
Bloody hell that's complicated !! What ever happened to hitting it with a hammer till it worked?
Link to comment
Actually pretty straight forward when you compare it to stripping and cleaning a set of problematic Mikuni BD38ST carbs.
Link to comment
  • Recently Browsing
