March 11, 201412 yr hi room,does any body know of a vacuum type fuel pump for an xj600 yamaha or is there a replacement i could get instead?ive heard that mikuni do a vacuum pump for a snow machine that apparently works but has anybody heard the same or know of another pump i can get, thanks jeff
March 11, 201412 yr Hi Jeff, Ok your looking for a vacuum pump for an XJ600, didn't think they had one on them, are you sure that this is what your looking for? or are you talking about the fuel tap under the tank which is vacuum operated? We need more info on your problem to come up with a fix. Also it might be an Idea to do an actual INTRO in the new embers section as this is a question on how to fix your bike and that should be in the workshop area, scroll down the front page and you will find it towards the bottom of the list. Your not alone in getting it wrong mate just trying to help you out here ok, you will get more response if you post in the right area after you have done an intro if your stuck then read some of the others to get the idea. Welcome to the YOC mate new people are always welcome.
