March 9, 201411 yr Hello Again Guys I've got a problem with my XJ6N's cooling system. I was on my way to work yesterday and got caught in a bit of traffic when I noticed the fan did not kick in when my bike hits 100 degrees. Once I got to work, I checked the fuse and found that it had blown, I replaced and let bike warn up in the hope fan would come on but it didn't. Any help will be much appreciated.
March 9, 201411 yr Blown fuses generaly means the device on the other end is knackered and pulling to many amps you can un plug the fan and feed it 12v direct to check it.
March 9, 201411 yr If it dosent blow the fuse then your ground is bad,or the power feed wire is rubed through to ground on the frame some where if the fuse keeps blowing.You can also jump the temp sensor for fan control and the fan should run constant
March 9, 201411 yr Author the replaced fuse did not blow. I will hard wire fan tomorrow, if that works any other suggestions?
March 9, 201411 yr PS you have to un plug and feed power and ground to the fan dosent matter wich way you hook it up it just might turn the wrong way but you will know if it works
March 9, 201411 yr Ya the fan control temp sensor un plug it then the fan will run constant or need to be jumped not exactly sure with your bike
March 9, 201411 yr thanks for advice dt502001 much appreciated.No problem just finnish the thread so the next person who has this problem has a starting point to work from
