hippyracer Posted March 9, 2014 Share Posted March 9, 2014 Hello Again Guys I've got a problem with my XJ6N's cooling system. I was on my way to work yesterday and got caught in a bit of traffic when I noticed the fan did not kick in when my bike hits 100 degrees. Once I got to work, I checked the fuse and found that it had blown, I replaced and let bike warn up in the hope fan would come on but it didn't. Any help will be much appreciated. Link to comment Share on other sites More sharing options...
dt502001 Posted March 9, 2014 Share Posted March 9, 2014 Check to see if anything is jammed in the fan,and that it turns freely. Link to comment Share on other sites More sharing options...
hippyracer Posted March 9, 2014 Author Share Posted March 9, 2014 Hello dt502001 fan turns freely Link to comment Share on other sites More sharing options...
dt502001 Posted March 9, 2014 Share Posted March 9, 2014 Blown fuses generaly means the device on the other end is knackered and pulling to many amps you can un plug the fan and feed it 12v direct to check it. Link to comment Share on other sites More sharing options...
dt502001 Posted March 9, 2014 Share Posted March 9, 2014 O ya put a fuse of the right amp in line Link to comment Share on other sites More sharing options...
hippyracer Posted March 9, 2014 Author Share Posted March 9, 2014 Okay, will do. I'm hoping it's not the fan as it is over £250 to replace. Link to comment Share on other sites More sharing options...
dt502001 Posted March 9, 2014 Share Posted March 9, 2014 If it dosent blow the fuse then your ground is bad,or the power feed wire is rubed through to ground on the frame some where if the fuse keeps blowing.You can also jump the temp sensor for fan control and the fan should run constant Link to comment Share on other sites More sharing options...
hippyracer Posted March 9, 2014 Author Share Posted March 9, 2014 the replaced fuse did not blow. I will hard wire fan tomorrow, if that works any other suggestions? Link to comment Share on other sites More sharing options...
dt502001 Posted March 9, 2014 Share Posted March 9, 2014 PS you have to un plug and feed power and ground to the fan dosent matter wich way you hook it up it just might turn the wrong way but you will know if it works Link to comment Share on other sites More sharing options...
hippyracer Posted March 9, 2014 Author Share Posted March 9, 2014 thanks for advice dt502001 much appreciated. Link to comment Share on other sites More sharing options...
dt502001 Posted March 9, 2014 Share Posted March 9, 2014 Ya the fan control temp sensor un plug it then the fan will run constant or need to be jumped not exactly sure with your bike Link to comment Share on other sites More sharing options...
dt502001 Posted March 9, 2014 Share Posted March 9, 2014 thanks for advice dt502001 much appreciated.No problem just finnish the thread so the next person who has this problem has a starting point to work from Link to comment Share on other sites More sharing options...
