GeorgeeHoward Posted March 9, 2014 Share Posted March 9, 2014 Hi all, I've posted on here before but not for a while so I may just look like a newbie to you all. Just wondering if anyone could possibly give me some help. I have a 1999 Yamaha DT, every time that it seems to get wet my bike seems to fuck up, the other week it happened and it would not tick over, it kept cutting out and not going past 7000 revs. I took out the spark plug which was so black, changed it and got it running again. It got wet again and the same thing happened, I played around with my air and fuel mixture and got it running fine, but then it always seems to change. At the moment it will tick over just over 1000 revs which is so low I know but if I turn my tick over up and then rev my bike, it will come down to 2000 revs and stay there for a few minutes before dropping down to 1500 Thank you Link to comment Share on other sites More sharing options...
Moderator Airhead Posted March 9, 2014 Moderator Share Posted March 9, 2014 I'd try fitting a new ignition coil Georgee Link to comment Share on other sites More sharing options...
GeorgeeHoward Posted March 9, 2014 Author Share Posted March 9, 2014 My ignition barrel is very bad, I am able to take the key out of the barrel whilst it's still turned on. Could this be the reason? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Moderator Airhead Posted March 9, 2014 Moderator Share Posted March 9, 2014 If it's that bad then change that as well as the ignition coil Link to comment Share on other sites More sharing options...
