March 4, 201412 yr Never owned or rode (a manual) bike before. What do I need to do to make sure she is in the best of condition. I'm a vehicle tech by trade so am mechanicaly minded. Need to know the basics really, it's a new bike so servicing will be done at dealer for warranty purposes for now. Anything I can read through to teach me the mechanics behind a bike is good as I have a lot of mechanical sympathy and like to know how things work ;-) Thanks guys
March 4, 201412 yr Aye tez, best run it in, just be canny on it,, but don"t crawl along, as its dangerous [ in todays traffic] get to the first service then after that, its yahoo time,,
March 4, 201412 yr read the owners manual, note the service data, what should be done and when, and then do it. start to build yourself up a decent toolkit, take your time, theres no rush
March 4, 201412 yr Author What's the best way to run them in? Bearing in mind I'll be learning to ride at the same time Sent from my C6603 using Tapatalk
March 4, 201412 yr keep the revs low and keep the bike clean servicing's done by the dealer so there's not much else you need to do
March 5, 201412 yr Author What's low revs on a bike? Only ever run in car engines that limit at 6500. Sent from my C6603 using Tapatalk
March 5, 201412 yr Your bike manual will tell you the running in period specific to you bike - so maximum number of revs for X number of miles. Each bike is slightly different you see so best to check what the manufacturer says for your own bike.
March 5, 201412 yr Another note, make sure your chain is lubed up properly (should be fine till your first service) but if you wash it before its service then you will need to lube it up. very easy to do: buy chain lube stick bike on center stand so rear wheel is off the floor put a sheet of news paper behind the chain so you dont get lube on rear wheel and floor spray lube on chain rotate wheel to next bit of chain repeat steps 4-5 til chain is lubed NOTE: some chain lube is a liquid than turns into a gel so that it gets into all the links in the chain sodont go mad other wise the chain will splatter shit all over your nice clean bike when you ride it. Also as part of your pre rider checks in the morning, before you start the bike up turn the ignition on take it off the stand, pull in the clutch and kick it into first and rock it till she rolls freely. you may feel a clunk as the clutch plates free up, as bikes use a wet clutch (clutch plates are submerged in the motor oil) over night they stick together so if you dont do the morning rock your sit on the bike half asleep, start her up pull the clutch in and kick her into gear and she will leap forward cut out and you may get the opertunity to drop her. Apert from those little things your be fine due to the servicing etc, once they are over and you take those tasks on for your self then a little more bits and bobs your have to do. Buy a Haynes manual and a load of metric sockets spanners and a good set of screw drivers and alen keys for your basic tool kit but seeing that your already a vehicle tech you most likely already have all these. Keep your eyes open on the road and treat everyone on the road as a wanker and keep a good distance between them and you and stay alert at junctions. But most of all enjoy it.
March 5, 201412 yr Author Another note, make sure your chain is lubed up properly (should be fine till your first service) but if you wash it before its service then you will need to lube it up. very easy to do:buy chain lubestick bike on center stand so rear wheel is off the floorput a sheet of news paper behind the chain so you dont get lube on rear wheel and floorspray lube on chainrotate wheel to next bit of chainrepeat steps 4-5 til chain is lubedNOTE: some chain lube is a liquid than turns into a gel so that it gets into all the links in the chain sodont go mad other wise the chain will splatter shit all over your nice clean bike when you ride it. Also as part of your pre rider checks in the morning, before you start the bike up turn the ignition on take it off the stand, pull in the clutch and kick it into first and rock it till she rolls freely. you may feel a clunk as the clutch plates free up, as bikes use a wet clutch (clutch plates are submerged in the motor oil) over night they stick together so if you dont do the morning rock your sit on the bike half asleep, start her up pull the clutch in and kick her into gear and she will leap forward cut out and you may get the opertunity to drop her. Apert from those little things your be fine due to the servicing etc, once they are over and you take those tasks on for your self then a little more bits and bobs your have to do. Buy a Haynes manual and a load of metric sockets spanners and a good set of screw drivers and alen keys for your basic tool kit but seeing that your already a vehicle tech you most likely already have all these. Keep your eyes open on the road and treat everyone on the road as a wanker and keep a good distance between them and you and stay alert at junctions. But most of all enjoy it. Perfect! I have got chain lubing gear in with the deal on my bike and as it will be daily then I shall be washing and doing chain clean/lube weekly. Yeah got too many tools and that last paragraph is something I will defo remember! Sent from my C6603 using Tapatalk
