YBR125 hunting then stalls
Ipswichram
This post is 3903 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I have a 61 plate YBR which has just started hunting between 1000-2000 rpm and then stalls. Any idea what can cause this? My local dealer has never heard of this happening before.
It has done 530 miles from new and has always been garaged when not in use.
Any help will be gratefully received.
Yeh " clean the tank, and carb. check the air filtre too while at it, ,new plug ,
Just done my ride-on mower, been outside all winter, done all of above, sprayed all wiring with WD 40 . Fired up first turn,, :icon_wink:
If all else fails you can borrow blackhats lawnmower !!!! Tho don't forget to bring it back when it runs out of fuel :biglaugha: :biglaugha:
