Not been on here in ages! XJ600n downshift
Hey peeps. All well? Just trawling info on really (stampy) heavy downshifts on the Divvy 600n, (98). I'm probably overdue a new clutch cable as I've got a wobbly lever :eusa_think: but for now it's relatively fine on the upshift etc. Really just going into first.
Any info grately appreciated.I may even buy you a drink!
Welcome back dude, definately check your clutch cable travel, if your clutch is dragging (cable too short) it will be harder to shift gears especially finding neutral
Try turning your clutch cable adjuster outwards a few turns and see if it makes a difference.
And be sure to adjust it at the engine first, then the lever if you need more adjustment.
