Posted February 28, 201411 yr hi all, need help i have just replaced my clutch plates and cable on my dt 125 its a 1993 dtr tried ajusting the cable and clutch as it say in the manual no look . the ajuster bolt gose all the way in untill it works but still its getting stuck in gear or wont change iv tried ajusting it from both ends of the cable and still nothing but iv been reading the u can ajust the push rod end of it from the mag side of the bike canu do this and how many thanks ronnie
February 28, 201411 yr Moderator did you make sure that the clutch friction plate with the larger internal diameter was installed as the 2nd one in...along with the rubber damper ring?
