February 28, 201411 yr Author if fitting a k@n filter would I need to get the fuel ratio fixed or is that only done when adding a scorpion exhaust has well
February 28, 201411 yr Yeh spurs, air filter will run without jetting, but with the exhaust mod, it will need adjustment,,, and its not easy to get right,,
February 28, 201411 yr Author would you kindly explain how the jetting is done has these bikes have no carbs
March 1, 201411 yr Assuming the filter is flowing more air the FI may need adjusting but some do this automatically but only within a small range, this only matters if a open exhaust system is fitted. There are a few cans on the market that claim there is no need to alter the fuelling.
March 11, 201411 yr Hi. Im also in need of advice on this. If I was to fit k&nfilters direct to my carbs will I need to replace the jets or do any other carb work for that matter?
March 13, 201411 yr Yes the jetting be totally different, also if you are not using the original airbox the tuned length will be shorter and effect the whole engines characteristics.
