February 25, 201411 yr Hi, I've got an old XJ900F that's been converted into a trike, I'd like to put different handlebars on it so that I don't have to stretch so much. My dad is a bit worried about the wiring then not reaching. Has anyoen got any suggestions for new wiring looms that will fit it. Thanks
February 25, 201411 yr You can't just fit a loom from something else to make it work, you have to lengthen the existing loom to make up the extra length, sorry and all but there are some things that can't be done and this is one of them, you could get someone to make up a loom from scratch for you but that might cost more than the bike/trike is worth. Wish you luck with your project. PS your also probably going to need longer cables as well but they should be easy to source and make up.
