Uh Oh I'm in trouble
Well I dropped the bike yesterday and now it will only go into first gear and neutral. It wont shift up. Im really pissed off. I'm hoping its just the clutch lever/wire that needs adjsuting? Any idea's guys?
Thanks
I,m presuming from your post that you dropped the bike on its left hand side....is the gear lever bent? Any other external damage? More detailed info?....
Yes on the left hand side, the gear lever I don't know the cluctch lever is
good chance the gear lever has aswell, if you go to change into second does the lever hit the bottom of the engine case?
It won't change into second. I'll Have to have a proper look in the light tomorrow.
can you you still pull the clutch lever in OK & does it return OK ?
stick up some pics lets have a look
Awe grouch"o , that bonnie bike . <_< . Yeh gear lever bent in, so will jam on upshift,,,bend it back out,,, :thumb:
As Blackhat say's bent gear lever but if you have to bend it out then replace it as well as the lever. Bad luck Groucho a shame to have bent your new bike but anything can be fixed. Put up some photos mate so we can see the damage and suggest how to fix it.
That's a shame Grouchy. Hope the cosmetic damage isn't too bad.
Thanks guys. It was the lever that was bent. I have just gently bent it back into place for now and will be ordering a replacement as soon as.
