DTR 125 Power Valve Cables
Hi, I hope someone would be able to help as getting frustrated with my sons Bike.
One of the Long power valve cables snapped. whist taking apart the PV would not move smoothly so I cleaned it and put back together making sure to get the right way round! the problem I have now when the solenoid does its cycle the PV finishes at 3 0 clock position instead of 12 and there for cannot adjust. please could anyone help. thanks
Sounds like it wasn't put back in the correct position
If you google dtr125 forum you can find lots of topics on it with pics
Hi,
thanks for the reply, yes you are right but when looking on the link does not give the info required, I have explained what happens below-
When the ignition is turned on the servo moves clockwise then anti, from the PV cable 1 ( shortest ) goes to Servo 1 or to 2 . thanks
