TZR 125 stator resistance readings
Hi,
My DT 125r just recetly lost its spark.
The electrics on it are from a tzr 2rh and i figured the problem might be in the stator since i just recently machined it to be able to adjust the ignition timing.
Anyways, i just took the resistance readings from the stator and got:
yellow and brown = 35 ohms
black and blackred = 723 ohms
whitegreen and whitered = 349 ohms
all the white wires from the threeway connector = 0,3 ohm
I cant seem to find the working resistance readings from anywhere...
Does anyone know these or have experience?
Thank you for help
