Bringing Her Back to Life
  • Replies 157
  • Views 25k
  • rzresurection
    rzresurection
    The whole look of the bike works - at least for me. That's what the bikes looked like before the faired bikes came in ('85 for the RZ). There was a transition where they had a small 1/4 fairing up top
  • rzresurection
    rzresurection
    Got some engine enamel on my bottom case half today. I should get my new shift drum and seals in this week. The tranny should go back together by next week.
Those turned out to work pretty damn good I must say! Did you figure out the resistors yet?
Nope, not yet. I only had a chance to figure out the way that I had the load resistor installed, was wrong. Lol.
Maybe later on today.
That's it!! Very sexy and look not so big any more.
HAha I had my setting wrong and missed this whole thread Great read I remember thoes good old days of 8-10 of us all on 2strokes foging out every intersection and the music of the pipes I can smell it now .
You didn't happen to go to the London bike show back in 87 and see my rz 350 there did you cause I had the tzr 250 body work on mine before anyone,everyone was running the harris or rickman farrings like your buddy I ll get a picture up later at the shop now working on the jeep (er um well supposed to be ) and have the pictuers on the other puter..
Your build is coming on nice, did you happen to weigh all the old suspension and new to see how much weight your adding?
Just put the resistor across positive and negative of the signal wires, in parallel. So you have your light hooked up to the output, and the resistor hooked up to the output, positive to postives of light and resistor, negative to negatives of light and resistor. This just simulates that there is enough load on the circuit so the flasher doesn't fault and think there's a bulb out! Hopefully that explanation made sense... there's a ton of diagrams out there too if you need to just google it! :D
I really do miss the days of 2 stroke bikes fogging up the streets. Now, I'm excited to see one in the street. I want to make sure I get my back on the road to join the dwindling minority.
I never made it to the 87 London show. I did like the TZR body work - I'd love to get one at some point. Post some pics up in my thread if you want. I don't mind a temporary hijack. Lol.
I still have all the original suspension components. I should do a comparison at some point. Would be some food numbers to know.
I didn't realize that they needed to be connected in parallel. I thought they needed more resistance, so I just connected in series. I'll use some jumpers to test, then wire permanently.
If you did it in series you wouldn't get 12v to your LEDs, since it'd split the load between the LED and resistor.
Aww wow that plate. Would love to get some small pressed plates on my bike.
Also that makes my heart flutter. Really really really gorgeous bike. I love them 80's look. Square rear ends. Rather that the triangle stuff they release these days.
Would love to have a blast on a big two smoker!
One day I will get myself an RD350 or something similar.
Thanks Calum. Some days, it gives me the same reaction.
It's a classic, but not an original/stock classic. I'm trying to give it a bit of a GP replica look.
I've never had a go on the bigger RZ500 (RD500 for you guys). I had a chance to buy one way back when, and was too chickenshit. I just stuck with the little brother. Lol.
If you have a chance to get a 350 - go for it. You won't regret it!!
Yeah tell me about it.
By the time I come to buy them the prices will be through the roof!
You guys in the UK have a lot of aftermarket goodies for them than we have. Bike prices in Canada are still 'reasonable' (but getting worse).
That one is sexy. Love the GP exhausts (both exit same side)
Got new jug studs installed tonight. Was also able to get a coat of primer on the bottom case half. Let er cure tonight and onto black tomorrow.
Jug Studs? what be them then??
That's okay. Prefer a fairing model. Still not a bad price really. For something of that age looks like in good condition.
