When I start my 1980 DT175MX (F) every now and then, it really takes a while to get it starting and idling normally. So I kickstart it after pulling out the chock, and kick it like no tomorrow and still feels reluctant to start. After a dozen kicks or so, it finally starts and idles for a few seconds then dies. This happens about twice, and by the time all this has happened the engine is pretty warm and can start with choke but then I'm able to push the choke back in and give it a few throttle blips to keep it running, after then it idles fine and quite smoothly. This has been happening since I got it. But it pays off since when its warm, its a wild torque beast :yeah:
So any help or advice is appreciated!
Thanks in advance
the engine is pretty warm and can start with choke" :eusa_snooty:
Thats gotta be wrong fawzi" .. your choke system is blocked, go to post " ybr not starting" it shows how to clean it out,, :yeah:
Blackhat250, your reply with a red font pretty worried me, am I making a mistake when starting it?
Btw I couldn't find where the post that contains the ybr not starting post is. Can you please help me with this?
When I start my 1980 DT175MX (G) every now and then, it really takes a while to get it starting and idling normally. So I kickstart it after pulling out the chock, and kick it like no tomorrow and still feels reluctant to start. After a dozen kicks or so, it finally starts and idles for a few seconds then dies. This happens about twice, and by the time all this has happened the engine is pretty warm and can start with choke but then I'm able to push the choke back in and give it a few throttle blips to keep it running, after then it idles fine and quite smoothly. This has been happening since I got it. But it pays off since when its warm, its a wild torque beast :yeah:
Thanks in advance
when starting from cold.....
switch on fuel
pull out the choke knob
kickstart with little or no throttle (choke wont work properly when throttle is opened)
when it fires up, use gentle throttle control to keep it going
choke off after about 1 minute
switch on fuel
The problem is that when it starts when choke pulled, I can't even get close to the throttle or else it will die. Even if a little touch.
I was stating , that you said CAN start with choke when warm,
heres the post,,,,
Check 'A' is not blocked
Check the gasket around 'B' is not broken / split
I will look at it, thanks for your help ;)
New spark plug might also help.
After standing awhile I find priming it with couple of kicks (fuel on, choke out and ignition off) also helps.
  • 1 year later...
Thanks Airhead for the photos/diagrams of the choke circuit. Your a legend.
