1979 DT 125 Changing Cylinder Head to 175?
Hey everyone, I haven't posted in awhile! I had a couple of questions about my 1979 DT 125. There are rumors that I can add a 175 head and pistons to a 125 to make the cc go up. Is this a possible thing to do?
- Change cylinder head from a 125 to a 175? What does this take to do and will it kill the bike overall? Anything helps!!
Cheers!
Yip" :yeah: i done it last year, needed= barrell [ 171cc stamped on side] matching head, piston/ pin/ and smal lend bearing, the small ends and pin are not interchangable, exhaust is same , carb jets need to change main to 150. pilot to 30 , it may be 30 in yours older dt125 was20, its a case of see how she runs.. :jossun:
Oh gaskets are bigger, base head,,
And will not kill her, [ same bottom end and stroke] vast improvement in power, and will pull 65mph easily, the clutch has 1 plate less on DT125 = ,,, may slip. at high rpm gearchanges,
